machine small end eye
Posted: Mon Aug 30, 2010 7:19 pm
by fred
Due to paranoia re' mb piston,has anyone machined a con rod small end eye to use 18mm pin?Rather than using ape rod
To enable suzuki piston use.
thanks
Re: machine small end eye
Posted: Mon Aug 30, 2010 7:54 pm
by Knowledge
I would not machine-out the small end to 18mm, but Harry Barlow had some 116mm rods with 18mm small ends. The holy grail of con rods, said Harry.
Posted: Mon Aug 30, 2010 11:02 pm
by tarmac tickler
a mate of mine machined a TV rod out to 18mm and it has worked fine for 2 year
Posted: Tue Aug 31, 2010 11:44 am
by GP Kevo
The WCLW Humiliator / Annihilator conrod is 116mm / 18 mm. Yamaha boat engine conrod sourced by Vince Mross. Lambrettaworks sells the Wiseco "HotRods" American made item.
Posted: Wed Sep 01, 2010 8:34 pm
by AUSSIE
Here are some part numbers for you
Yamaha outboard motor con rods.
these engines are triple cylinders making 30-40bhp
648-11651-00 110mm long 29mm big end (to take 22mm crank pin) 22mm little end (to take 18mm) both ends 18mm wide
6h4-11651-00 116mm long 29mm big end 22mm little end both ends 18mm wide
easiest to have big end width machined down to 15mm to fit in the standard webs or have the webs machined to take the 18mm rod width.
Hope you can understand that, havent written it up very well sorry. Dave
