Any tips on lowering cylinder head compression
Posted: Sat Aug 21, 2010 9:20 pm
by corrado
I've been told that my MK 1 Mugello 225 head is "Reaper tuned" to 10.5 : 1 compression but apart from matching up inlet & exhaust to the manifolds it's had no further tuning, so it should be lowered to 9.5 : 1. How do I go about it? Does all material have to be removed from the bowl or can I remove a small amount of the squish machined part to make the bowl wider as well as deeper?
Also posted on LCGB.
Re: Any tips on lowering cylinder head compression
Posted: Sat Aug 21, 2010 9:50 pm
by bristolmod
2 head gaskets as per original SX150?
Posted: Sun Aug 22, 2010 7:35 am
by ScooterLoopyJohn
From what i have seen of these heads your best bet is to start with a new 200cc indian head and recut the bowl and squish band to exactly match the piston radius. By this i do not mean a staight turned angle but a correct radius cut to suit. done the last 6 engines this way all with good results. pm for details. PS the new bowl and squixh band is CAD drawn and then CNC 3D milled into the head. For small block engines i start with a 125 head and big blocks with a 200cc indian fat head. Very good for 186 mugello engines as the original heads are way off.
Posted: Sun Aug 22, 2010 4:26 pm
by dirtyhandslopez
ScooterLoopyJohn wrote:From what i have seen of these heads your best bet is to start with a new 200cc indian head and recut the bowl and squish band to exactly match the piston radius. By this i do not mean a staight turned angle but a correct radius cut to suit. done the last 6 engines this way all with good results. pm for details. PS the new bowl and squixh band is CAD drawn and then CNC 3D milled into the head. For small block engines i start with a 125 head and big blocks with a 200cc indian fat head. Very good for 186 mugello engines as the original heads are way off.
Good to know, thank you.
Was wondering what to do with all those 125 heads on the shelf.
Posted: Mon Aug 23, 2010 11:55 am
by corrado
bristolmod wrote:2 head gaskets as per original SX150?
As SLJ pointed out elsewhere ........
But then you lose the squish band which needs to be 1-1.3mm to work well. Its all about the heat in the piston being transfered to the head which stops working well over 1.5mm squish.
Posted: Mon Aug 23, 2010 5:18 pm
by cezeta
can you not increase the volume with a ball type grinder bit.......or buy the right one you tight ass
Posted: Tue Aug 24, 2010 12:04 am
by corrado
cezeta wrote:can you not increase the volume with a ball type grinder bit.......or buy the right one you tight ass
I only had one day to work on it, Sunday, all the cylinder head shops were shut.
I've got plenty of lower comp heads (TS1 / RB) but the Muggy head is machined so that it sits inside the cylinder.
Did what I could with a dremmel but didn't want to go mad and possibly make things worst. I should have taken before and after cc measurements of the bowl but needed a syringe to do it accurately and I didn't have one.
