scootRS vs sterling exhaust
Posted: Sat Aug 21, 2010 7:17 pm
by dodobeckam
does any one know if the to budget range pipes are the same as i`ve been told that the scootRS pipe is ok for the money.....
Re: scootRS vs sterling exhaust
Posted: Sat Aug 21, 2010 7:25 pm
by Lamaddict
I think they are based on the PM exhaust. Scootrs gear is usually better than Sterling stuff. Not many of the reputable dealers stock Sterling gear.
Posted: Sun Aug 22, 2010 10:13 pm
by corrado
I've sold both at some stage and apart from the name on the endcan they looked identical. Used a scootrs version on my Imola and with 5.4 gearing it was great.
Posted: Mon Aug 23, 2010 11:14 am
by chez
hi scootRS pipe and sterling are very similar, end cans are inter-changable, down pipes differ slightly the sterling pipe being easier to fit due to pipe coming down further so a spanner can easily be used on the awkward side where as the scootRS pipe has a dink in pipe and runs very close to exhaust stud making fitting more difficult. Performance wise very similar on an imola. The reason i have this info is my sterling pipe broke across down pipe had welded then broke at main bracket at which point i purchased scootRS pipe second hand of flea bay, both pipes offer fairly good value for money in budget sector
