beedspeed piston
flameboy
Hi
Is this piston any good for a ts1?
http://beedspeed.com/product_info.php?c ... ts_id=8833
thanks
gaz_powell
KHC are a reputable taiwanese piston company who make loads of pattern jap piston - DT, RD, etc would be interesting to find out what they are from or if Beedspeed are having them made.
worth a punt depending on what state of tune you have - ideal for a steel lined TS with the oversize and 16mm gudgeon and the height means no crank conversion
worth checking head profile if you do use one
