Engine mounts
Posted: Tue Aug 17, 2010 1:15 pm
by dapper
On the left the original Indian mount with rubber going all the way through, and on the right a brand new SR SIL two hole mount with rubber going only half way through. Could this change in manufacture be the cause of more frequent mount failure?? I also have a brand new three hole SR mount which only has the rubber going half way through.
A possible tip for that awkward bridge piece nut that is so close to the exhaust downpipe. This type of nut has a built in washer (don't know what they are called), but as you can see, it can be held upside down in the ring spanner while you do the bridge piece screw up from above old smiley 4
Re: Engine mounts
Posted: Tue Aug 17, 2010 11:17 pm
by Knowledge
Thanks for highlighting these two issues.
The "half-way-through" rubber is far more common than the "all-the-way-through" rubber. I prefer the latter, but they are hard to locate. Does anyone know who sells them?
Some people, especially "Mark", recommend the double mounts on the chaincase side. Andy Francis sells them.
The nut (and I can't remember the name either) is good, but many people don't realise that the whole bridge-piece thing is much easier if you remove the rear shock first. It took me about 20 years to realise.
Re: Engine mounts
Posted: Sat Aug 21, 2010 12:10 pm
by dapper
They are called flange nuts.
