wiring up Horn
Posted: Tue Aug 17, 2010 10:30 am
Hi - Just coming to end the of my restoration and checking all my wiring is correct.
The wiring diagram says take the white wire from the light switch and connect it to the horn. Obviously the white isnt long enough to connect straight into the horn, so Im assuming I need to connect it to a new wire via the junction box/bulb holder then take that wire down to the horn instead? if thats the case, can anyone point me in the direction of where I can get said wire?
By the way, its for a li150 s3, 12v ignition, MB loom.
ta
ta
