Page 1 of 2
A Flywheel, a puller and an annoyed person
Posted: Sun Aug 15, 2010 10:45 pm
by Bilko
Stripping my old Muggy 225 and tried to fit the flywheel puller and it wouldn't go. I'm sure I've f@@ked the start of the thread. I bought another puller to make sure.
So now I know it's not the puller, how can I get my flywheel (varitronic) off?
:oops: :( :roll:
Re: A Flywheel, a puller and an annoyed person
Posted: Sun Aug 15, 2010 10:55 pm
by cezeta
mine is a bit of a odd fit and always has been. can you not use a three legged puller?
Posted: Mon Aug 16, 2010 6:15 am
by joespeed
now that you have two pullers,cut a slot or two straight through the threads to make it look like a tap try screwing it in,should cut its own thread to a damaged flywheel !
regards
joe
Posted: Mon Aug 16, 2010 9:37 am
by Bilko
A three legged flywheel puller? :?
I'll try and cut one Joe.
Posted: Mon Aug 16, 2010 2:27 pm
by Triken
Spot on Cezeta. A three legged puller would work - I have done it myself. Not that they were built for that, I seem to recall getting a clutch out of a moped some years ago, and that was the tool required.
Posted: Mon Aug 16, 2010 3:05 pm
by Bilko
Just looked up a 3 legged puller, but I'm not sure I can get it to grab hold.
Posted: Mon Aug 16, 2010 6:18 pm
by Bilko
Anyone got any other ideas?
Posted: Mon Aug 16, 2010 6:28 pm
by Dazza
I have used a three legged puller but had to grind it a bit to get it to fit, get it tensioned up and give the centre part a sharp crack with a hammer and it should pop off quite easily.
Posted: Mon Aug 16, 2010 8:20 pm
by wack 63
What I have done in the past is to use a really sharp screwdriver to gouge the damaged thread out enough to get the puller started.The trouble with the Varitronic is there isn't a dust cap to keep all the crap out the threads so I spray mine with aerosol anti sieze to stop rust etc.
Posted: Tue Aug 17, 2010 10:33 am
by corrado
Is it possible to drill out the rivets holding the flywheel fan to the boss? Once the fan is off the 3 legged puller should work.
