TS1 fuel
Posted: Thu Aug 12, 2010 8:55 am
by ts200
is it worth using super unleaded in a ts1?
i only use normal unleaded in my mallossi vespa with no troubles.
cheers
Re: TS1 fuel
Posted: Thu Aug 12, 2010 8:58 am
by Muttley McLadd
Surely that would depend on how high you've set your compression.
Re: TS1 fuel
Posted: Thu Aug 12, 2010 9:17 am
by ts200
it is a standard 200 kit with 1.5mm squish.
Re: TS1 fuel
Posted: Thu Aug 12, 2010 8:03 pm
by roadrunnerian
i use super unleaded on my ts1 225 and my 172 malossi vespa on the vespa i have a pm head and they recommended super unleaded as do af rayspeed with the ts 1
Re: TS1 fuel
Posted: Fri Aug 13, 2010 9:35 pm
by soosh
ts200 wrote:it is a standard 200 kit with 1.5mm squish.
Alright dude? I always use standard unleaded in all of mine.
Re: TS1 fuel
Posted: Fri Aug 13, 2010 9:54 pm
by Bufficus
Set your bike up on standard pump fuel with a sensible comp head and you shouldn't have a problem. Various reports now suggest high octane fuels can be detrimental to 40 year old 2 strokes due to additives etc designed for modern cars. Also, at many rallies, off the beaten track, it is often difficult to find high octane. I run my TS1, RB and Dragster on the local ASDA brew with SIP oil. You don't want a fussy engine.
Re: TS1 fuel
Posted: Sat Aug 14, 2010 12:13 pm
by soulsurfer
My TS1 is set up to run super unleaded, but it wouldn't kill it to run regular unleaded. It's been shown on a dyno that Tesco super unleaded gives the best power
Re: TS1 fuel
Posted: Sat Aug 14, 2010 1:21 pm
by ts200
cheers lads, i'll set it up on normal unleaded, its true what you say when your in the arse end of nowhere you struggle too find super unleaded.
Re: TS1 fuel
Posted: Sat Aug 14, 2010 9:54 pm
by soosh
soulsurfer wrote:My TS1 is set up to run super unleaded, but it wouldn't kill it to run regular unleaded. It's been shown on a dyno that Tesco super unleaded gives the best power
But if you need a dyno to show that then it aint worth paying the extra.
