Best tubes for lambretta front wheel (li series 1-3)
Posted: Wed Aug 11, 2010 11:25 pm
by Soulpunk
whats the best front wheel tube available with correct 60° or so valve and offsided valve position ?
there was a pirelli a michelin and an asian tube for choice, only the asian beeing correctly offside positioned as far as i remember...
whats best availbale now and where are these available ?
cheers
Re: Best tubes for lambretta front wheel (li series 1-3)
Posted: Thu Aug 12, 2010 6:19 am
by Toddy
Two types i use are the correctomundo ones Rich pressley and other dealers sell and the MB Kings brand Tube
Posted: Thu Aug 12, 2010 6:41 am
by soulsurfer
The correctomundo are Mypol and available from Corrado (www.justlambrett.com) on here, it's a perfect fit. I also install a tyre sealant with these.
Posted: Thu Aug 12, 2010 2:55 pm
by corrado
The Mypol ones have the valve situated 6mm from the centre line of the tube as the hole for it in a Lambretta rim isn't in the centre either. The valve angle on the Mypol is 55 degrees. 8-)
Posted: Thu Aug 12, 2010 2:56 pm
by kejj
Is someone trigger happy today? 3 posts on the same question?
Posted: Thu Aug 12, 2010 5:36 pm
by 10 inch Terror
I fitted Mypol ones from just Lambretta but i changed the valves for a better quality type for piece of mine, but the actual tubes are spot on.
