Stripped casing threads
Posted: Sat Aug 07, 2010 12:33 pm
by jimmo
I have a couple of stripped casing threads where the bracket for my Taffy pipe mounts.
What size helicoils will I need and where's the best place to get em from?
Thanks
Re: Stripped casing threads
Posted: Sat Aug 07, 2010 3:45 pm
by Supereibar
PM cezeta he knows a good brand!!
Posted: Sat Aug 07, 2010 6:26 pm
by joespeed
you could try step studs,tap the hole 7mm and just screw step stud in,
i think 8mm to 6mm are also available,
regards
joe
Posted: Sat Aug 07, 2010 7:16 pm
by fred
m6 thread insert,such as helicoil. check on e bay.
used 'em for years.
Posted: Sat Aug 07, 2010 7:37 pm
by mark
The main exhaust side casing studs are 8 x1.25 mm only early series 1&2 are 6mm
Posted: Sat Aug 07, 2010 7:41 pm
by soulsurfer
jimmo wrote:I have a couple of stripped casing threads where the bracket for my Taffy pipe mounts.
Thanks
Is that the tailpipe end or exhaust body end?
Posted: Sat Aug 07, 2010 8:58 pm
by fred
i thought he meant muffler bracket,heliciols good for ali thread repairs.
Posted: Sat Aug 07, 2010 10:39 pm
by jimmo
fred wrote:i thought he meant muffler bracket,heliciols good for ali thread repairs.
Yes Fred, its the 3 that hold on the rear bracket for the end can.
So I go for the m6 inserts then?
Should get those on ebay?
