Will this run
Posted: Wed Aug 04, 2010 3:38 pm
by Jazzy
Lambretta barrel,
exhuast 180 degrees
inlet 130
transfers 117
what do ya recon.
Re: Will this run
Posted: Wed Aug 04, 2010 8:09 pm
by jonny snatchsniffer
it will run, the inlet and transfers are a little low tho for the exhaust timing so it will be a bit peaky
Re: Will this run
Posted: Thu Aug 05, 2010 8:05 am
by fred
think 130 inlet must be a typo,sure it's not 150?
personally i'd prefer more transfer timing,but that's just me perhaps.
fred
Re: Will this run
Posted: Thu Aug 05, 2010 3:12 pm
by Jazzy
a bit off the piston might help then :?:
ps this is for a straightliner
Posted: Thu Aug 05, 2010 9:31 pm
by tarmac tickler
if you are going sprinting mate i would say those port timings are extremely conservative, even more conservative than maggy thatcher!!!
Re: !!!
Posted: Thu Aug 05, 2010 11:14 pm
by Jazzy
tarmac tickler wrote:if you are going sprinting mate i would say those port timings are extremely conservative, even more conservative than maggy thatcher!!!
can you point us in the direction of somthing a bit more Nick Clegg then
Re: Will this run
Posted: Fri Aug 06, 2010 7:08 am
by Special X
190 exhaust
130 Transfer
158 Inlet
Wouldn't be over the top for sprinting
Re: Will this run
Posted: Fri Aug 06, 2010 3:37 pm
by tarmac tickler
an experimentl iron barrel going on the dyno at the run to the shires this weekend..
exhaust 202 :D
transfers 150 :D
inlet (forgot to measure it) :oops: :oops:
gear box gt200 46/15
will post results sunday
Re: Will this run
Posted: Sat Aug 07, 2010 1:14 am
Jazzy wrote:a bit off the piston might help then :?:
a bit off the piston will help but it would be better to work the inlet so it has more port time area
widen it and lower the inlet but leave a few mm so the piston skirt covers the port id also go with around 165 withe inlet
trouble is gonna be getting the transres up to about 130 ish
