Which tank....
Posted: Tue Aug 03, 2010 4:39 pm
by sydduckett
Have narrowed it down to these 2 with the Sundar being the favorite due to price. I want the original look with the seam and it will be painted, anyone got any feedback or know of a better deal before i splash the cash...
Ta Sef
Re: Which tank....
Posted: Tue Aug 03, 2010 5:01 pm
by Bilko
Why not get in touch with Corrado on here?
I think you'll find his are pressure tested too
Re: Which tank....
Posted: Tue Aug 03, 2010 6:10 pm
by Monty
I got the stainless version £95 + P&P recommend you test fit before you paint I found them a tight fit between the tank and tool box. I should have trimmed 2 or 3 mm off before fitting. No room for the rubbers at the front when sitting good, damn sure the paint would have been damaged fitting the straps, but good quality all round. I also reduced the Length of my tap pickup as I was going onto reserve with 4 or 5lts still in the tank.
Re: Which tank....
Posted: Tue Aug 03, 2010 6:14 pm
by sydduckett
Monty wrote:I got the stainless version £95 + P&P recommend you test fit before you paint I found them a tight fit between the tank and tool box. I should have trimmed 2 or 3 mm off before fitting. No room for the rubbers at the front when sitting good, damn sure the paint would have been damaged fitting the straps, but good quality all round. I also reduced the Length of my tap pickup as I was going onto reserve with 4 or 5lts still in the tank.
Monty was this the sundar one? If so where would you have shortened it, presume the rear lip being cut back?
ta
