34mm Mikuni on an RB 225 kitted engine.
Posted: Thu Jul 29, 2010 5:04 pm
I was running a 30mm carb (Delorto) on my RB 25 kit and it went like stink, i have recently been offered a 34mm Mikuni carb with the promise it will improve the performance. Has anyone had any experience of fitting this carb to this kit, i know that AF Rayspeed recommend the 34mm Delorto to maximise performance. But i havent heard anything about fitting the Mikuni to this kit.
Also if i fit this carb will i have to change the inlet manifold (i would prefer the solid type as opposed to the rubber mounted type) as the rubber mounted unit i presently have is vibrating too much and causing the carb to rattle on the running board.
Apprieciate the input guys, anyone got any advise ???
Cheers
Cheers
