Engine building
Posted: Sun Jul 25, 2010 7:59 pm
by LI150
Dont know if this is what I am intending to do just a thought really but what could I use on my current engine if I built an engine using a 200 crankcase using mine as a donor.
My engine is a series 2 li150. It does have a mec gp crank and electronic ignition so can use these but what else and what would I need to buy..
Re: Engine building
Posted: Sun Jul 25, 2010 8:08 pm
by Diablo
Gearbox,sprokets and chain,clutch
Re: Engine building
Posted: Sun Jul 25, 2010 9:55 pm
by mark
bearings and seals and gasket set
Re: Engine building
Posted: Mon Jul 26, 2010 8:29 pm
by LI150
Diablo wrote:Gearbox,sprokets and chain,clutch
I take it you meen these are ok to use..
Re: Engine building
Posted: Mon Jul 26, 2010 11:14 pm
by Diablo
Sure. Standard LI150 with 15/46 sprockets has a final drive of 5.2 same as GP200. If they are in good nick no reason why you cant use them.
The clutch wil need new corks and springs but everything else is useable. Check you haven't got the sprocket with springs in which thinking about it you may well have.
