choke cable
Posted: Fri Jul 23, 2010 4:45 pm
by scootcoot
Is there a way of shortening the inner choke cable ? just cant get it to open enough and having to resort back to a flip !! :cry:
Re: choke cable
Posted: Fri Jul 23, 2010 4:54 pm
by LI150
Can you get a longer choke elbow on the carb to take up the slack???
Re: choke cable
Posted: Fri Jul 23, 2010 8:06 pm
by wack 63
Some will ,with a bit of tugging or filing pass thru the outer caps and then just make up a longer outer and re-fit.You can also be lucky sometime and heat the solder up and move the nipple end and resolder.
Re: choke cable
Posted: Fri Jul 23, 2010 8:13 pm
by CPH Lambretta
What you need is one of the knowspeed adjustable choke cables, you can PM him on here or look in the dealer innovations section
Re: choke cable
Posted: Fri Jul 23, 2010 8:39 pm
by bsso78
Contact Chiselspeed for a fully adjustable choke cable which will fit any carb and last for years.A quality product that takes a couple of minutes to fit,ive never seen the ones that bloke that calls himself knowledge (sorry cant remember his real name) does and im sure they are fine but the chisel ones are superb
Re: choke cable
Posted: Fri Jul 23, 2010 9:41 pm
by Knowledge
Hi,
I do a non-adjustable version made to fit your combination of carb and location (TS1 side, or traditional side).
I did a batch of adjustable cables, but I couldn't get a regular supply of in-line adjusters to continue production.
If you want one made to order for £5 delivered, let me know.
Re: choke cable
Posted: Sat Jul 24, 2010 8:53 pm
by lammydave
get an old gear cable outer and cut it to the desired length.. do away with the elbow at the same time
Re: choke cable
Posted: Sun Jul 25, 2010 8:38 pm
by scootcoot
lammydave wrote:get an old gear cable outer and cut it to the desired length.. do away with the elbow at the same time
Thanks ! great tip ! made one today and it works a treat !!! :D
Re: choke cable
Posted: Tue Jul 27, 2010 5:23 pm
by lammydave
i use this on all my lammys... glad it worked for you, too
david
