Speedo Problem
- bicboy
- Main scooter: S2, EID Built, Diablo tuned...
I have an original S2 speedo it is in Mint Condition but is acting like a Geiger Counter
. Are there any easy ways to solve this problem, or does anyone restore them
Everything must be done to the Extreme.....
jem booth restores them and calibrates them as well
chez
- Main scooter: li150 special
try routeing the cable as smoothly as pos and lubricating bear in mind the cable is acting like a spring winding up and unwinding as its possible the speedo is ok also check the drive for deterioration another thing to try if available is fitting speedo to another scoot to varify if bolloxed or not good luck!
Mick I send my original speedos to Jem. Once you get him to answer the phone the service and workmanship are 1st class.
