SX250LC custom
Posted: Mon Jul 19, 2010 5:40 am
Edit: Moved it from the show your scoot section, thought it would fit better here..
Hi one of my bikes is being build by SSC.
Most of the welding is done, just tank caps for an aero style one, some small holes, rear light holder and some small mod on the fork. it should be finished in a week or 4-6, according to Pat (usually that means a bit longer, haha)
Short Part list, of the more interesting parts, (as you can see) most not installed yet...
Chiselspeed Adv/Ret, Clausstudios Custom CNC Engine Blocks Orange & Orange Custom RearLens
, CS Enginering Custom Hydraulic Clutch, Water Temp & EGT Gauge 60mm, Loopy Quick Action Throttle Wheel, Clutch & Break Master Cylinder Ducati, Custom CNC Ducati Levers, 6061 T6 Alu Coolant Catch Can, 12 Volt Pump, MB Liquid Cooled head, Weatherman Whitewall HS, Super small battery 12v, Tailtech Vapor Digital Computer, MB Layshaft, BGM Chrome Front Shocks, 3 Stage progressive Fork Springs, 120 Watt Stator Plate, Rear+Front Hydraulic Brakes, R1 Rear Shock, RB25 Cylinder Kit, SIL Electronic Ignition, Lightened Flywheel, 72mm Asso Piston, GP Gearbox, JAP 5 Plate Clutch, Custom CNC 6061 T6 Rear Hub to match front hub, Customized GP side Panels, 15.5 Lit Tank with Cutout for TMX Carb, Custom LD Glove Box, Custom Orange Hydraulic and throttle Cables
PS i am from Holland, so no comments on orange and the selection of orange parts, thx
