Steering lock Question
Posted: Fri Jul 16, 2010 9:10 pm
by Bilko
The curved part of the semi circle faces down to push the wee barrel on the spring doesn't it?
Re: Steering lock Question
Posted: Fri Jul 16, 2010 9:23 pm
by rog60
Yep....
Posted: Fri Jul 16, 2010 10:23 pm
by Bilko
Thanks Rog. Had to check as i thought I was doing something wrong. Lock doesn't fit because the pin in the spring won't depress right down. I know the steering lock is worthless, but I'd like something to go right for a change.
Posted: Sat Jul 17, 2010 12:11 am
by rog60
check you're not trying to depress spring and plunger when handlebars are in locked position, i.e. turn them to right/left to clear the tab that the plunger rests against in the locked position....
Posted: Sat Jul 17, 2010 9:10 am
by Bilko
Cheers Rog. Did that :/
Posted: Sat Jul 17, 2010 10:33 am
by ArmandTanzarian
I bought an aftermarket lock and the pin was too fat to go through the hole in the headset. I had to take it all apart and file it until it dropped all of the way in.
