TS1 225 No Packer
Posted: Wed Jul 14, 2010 5:50 pm
by Jazzy
just stripped my ts1 225.
it was not reving out and lacked top end speed. found the rings had a 1.2 mm gap with plenty of signs of blow past.
took the reed block out to check reeds and moticed that there is no 5mm packer this leaves the piston close to the stops.
how much is this effecting proformance?
Re: TS1 225 No Packer
Posted: Fri Jul 16, 2010 2:27 pm
by gaz_powell
i`ve got one with a packer and one without - both same set up (standard reed block/exhaust/gearing/carb) cant say there is any noticable difference
i only put a packer in to see if it would make any difference
Gary
Posted: Fri Jul 16, 2010 6:41 pm
by blue
You need a packer with yam reed blocks but with standard you don't.
Posted: Sat Jul 17, 2010 10:43 pm
by Jazzy
i filed a couple of mm off the stops nearest to the piston.
it looked like it would be a struggle for the gasses to get to the boost port.
fingers crossed.
