Damper advice
Posted: Wed Jul 07, 2010 1:05 pm
by druist
i got the measurements wrong and welded my brackets too low. I would say its well over an inch would the effect be "no damping"?
Also, are adjustable dampers worth that amount of money if i have an imola?
Re: Damper advice
Posted: Wed Jul 07, 2010 3:29 pm
by shocky
WHAT MEASURMENT DID U USES? I DO ALL MINE (AND OTHER PEOPLES) 255MM FROM THE POINT IN STICKYS TO THE TOP OF THE BRACKET ,AS LOND AS THERES SOME TRAVEL BOTH WAYS WITHOUT ANY BOTTOMING OUT YOU WILL BE OK
Re: Damper advice
Posted: Fri Jul 09, 2010 1:26 pm
by matthew
Should be just about perfect for using the Kawasaki steering damper type dampers then :)
Normally have to use a spacer which is roughly about an inch and a half long with this type of damper to mount them in lambretta fork brackets so your damper mounts should be just about spot on.
