Headset Top
After ordering the one in Scootering last year and never receiving,I made my own with a little alloy welding from a chap I know.Scoot now has fuel gauge,rev counter,speedo etc .Only down side was having to fit a modified Vespa battery holder in toolbox and a seperate switch to turn it on but works fine.ImageImageImage
Knowledge
Very neat, and lots of info on a small display. Tidy installation too.
The battery issue could be solved with a small battery from a burglar alarm. They are readily available, sealed and can be mounted at any angle. Although they only have small terminals, you won't be drawing much power to run this display. It's not like you need to fire-up a starter motor from the battery.
Something like a 3.2Ah 12v jobbie like this: http://www.yuasabatteries.co.uk/np32-12-yuasa-9-p.asp at about a tenner, or check out the data sheet for all their NP range (including physical dimensions) here: http://www.yuasabatteries.co.uk/data-sh ... ds-4-w.asp
If you want 4.8mm terminals and a crimping tool to fit them, then I have plenty in stock.
Martin
Thanks for that ,that's the type of battery I used and made the carrier smaller.Battery is charged from a varitronic regulator.
Nice job wack 63, it looks like it has always been there. Nice one.
Diablo
Yes very impressive it looks like it grew there.
fibreglass
Main scooter: gp
Very pleasing to the eye its allways nice to see someone take a little pride and care in there work !
    Users browsing this forum: No registered users and 74 guests
