Whats the best ignition conversion...
ramblin66
noob
Got a bog standard 6v non battery Li 150.
Want to change the 6v to a 12v.
Do I convert the stator plate to a 12v and what are the drawbacks
OR go the whole hog and convert to electronic ignition and if so,
whats the best one and do I need to add a battery.
Would appreciate your views.
Thanks.
Ramblin66.
Lamaddict
SIL Stator with the best regulator and CDI you can afford.
Lamaddict wrote:SIL Stator with the best regulator and CDI you can afford.
yep, would go with that, and if you had to choose, spend more on the CDI.
no need for a battery unless you are running anything extra to the standard lights, but you can then get a better horn, and a brake light that doesn't dim the headlamp...
    Users browsing this forum: Baidu [Spider] and 10 guests
