Re: JL4 cracking
Posted: Tue Jun 29, 2010 8:34 pm
by sean brady scooters
its a common problem on jl 4 s,
maybe stronger springs would also help as well as extra bracing
Re: JL4 cracking
Posted: Tue Jun 29, 2010 10:16 pm
by wack 63
Now you tell me just as I have one coming in the post :cry:
Re: JL4 cracking
Posted: Tue Jun 29, 2010 11:20 pm
by gadgetman
It's a very common problem with the JL4 I remember watching one on a mates GP totally disintergrate on the way back from Brid a couple of years ago after the YSA Coast2Coast and when I say disintergrate I mean disintergrate. The main chamber cracked straight down the middle along it's length as if it had been hit with a sledge hammer and fell to the road surface where it just exploded into a thousand bits . The well known Lambretta racer & tuner Vinnie Smith was the rider for those of you that know him.
Re: JL4 cracking
Posted: Wed Jun 30, 2010 7:34 am
by bazman
Re: JL4 cracking
Posted: Wed Jun 30, 2010 9:08 am
by leigh
bazman wrote:This might be an option?
http://www.ekmpowershop12.com/ekmps/sho ... -931-p.asp
Good exhaust but my rubber mount for the tail can disintegrated in france got it solid mounted now.
Re: JL4 cracking
Posted: Wed Jun 30, 2010 12:22 pm
by Dell Oughta
I've had two JL4's crack, both in the same place as edens. The snail one I have also cracked on the ubend that the muffler is attached to and cracked where the bracket is joined to the expansion chamber...twice (makes me wonder why I bought the the second one :? )
Mike
Re: JL4 cracking
Posted: Wed Jun 30, 2010 5:23 pm
by Andy Pickering
Does the JL2 have the same problem then..???
Re: JL4 cracking
Posted: Thu Jul 01, 2010 10:00 pm
by wack 63
I can see why they may crack as they are a lot thinner steel compared to the JL3 I also have.Think I will double spring the manifold joint and see ;)
