Page 1 of 2
Lambretta Tuning Options
Posted: Tue Jun 29, 2010 10:43 am
by tomdavid1988
Done bought a lambretta at the weekend, looking at possible tuning options, always fancied a TS1 but have a set of GP150 casings in the shed, as I know f@@k all about Lambrettas, i'm just looking for some tuning advice, i.e what sort of kit I could go for on 150 casings and if I was to go for a TS1 what would be the best starting point, new SIL engine?
Re: Lambretta Tuning Options
Posted: Tue Jun 29, 2010 12:01 pm
by GP Kevo
No need for TS1 when you can go RB20 (RB200), made for small block Lambrettas.
http://www.afrayspeed.co.uk/online_catalogue/rb/rb.html
Posted: Tue Jun 29, 2010 12:32 pm
by corrado
Or there's the Imola kit. RB20 and Imola kit will get around 20bhp out of the box with decent carb and expansion exhaust.
Posted: Tue Jun 29, 2010 12:49 pm
by SpanishSX200
You can also go for the Race Tour 190, this will run with the carb on the standard side and no reed block. I have an RT 230 which is excellent, running with a PWK 28 mm and a Dev-tour exhaust.
Posted: Tue Jun 29, 2010 1:37 pm
by tomdavid1988
like the sound of the RB20 would this be a good bolt on kit then, no porting neccesary? what about gearing etc, I have standard GP150 gears, but don't have a carb or clutch.
Posted: Tue Jun 29, 2010 1:54 pm
by Stokie
tomdavid1988 wrote:like the sound of the RB20 ............. but don't have a carb or clutch.
You'll deffo need a carb and a clutch - that's for sure ;)
Posted: Tue Jun 29, 2010 2:15 pm
by tomdavid1988
Bugger, that'll be why my P2 ain't running right then!
Posted: Tue Jun 29, 2010 3:36 pm
by corrado
tomdavid1988 wrote:like the sound of the RB20 would this be a good bolt on kit then, no porting neccesary? what about gearing etc, I have standard GP150 gears, but don't have a carb or clutch.
AF close ratio gearbox would be better option.
RB kits need a special RB exhaust and RB 20 needs a crank with a TV length conrod.
Advisable with any kit to match up transfers rather than bolt it straight on.
Posted: Tue Jun 29, 2010 4:09 pm
by drunkmunkey6969
For a Lambretta 'newbie' i'd recommend somthing a bit less 'demanding' than the RB20, for economy i'd go for a good old fashioned porting job on a 175 or 190 kit! Bolt on a cheap sterling pipe and a 30mm Delly and yer off!
For a bit more 'umph' and exotica, try the Muggello or Imola, you can still use the sterling and Delly, and/or spend a bit more on gearing and so on.
At the 'top of the tree', the RT kit is a bit more dosh and considered fast touring, RB20 is a revvy beast and needs specific crank/exhaust/carb /gearing combos to make the most of it.
Choices, choices!!! ;o)
Posted: Tue Jun 29, 2010 6:19 pm
by shocky
depends on what you want and how much money, most of that engine wont be usable on a RB and if you dont know much about lammys then someone is gonna have to build it for you a starting price for that engine to do it your self with good(altho not the best) components is £1500
