standard carb mods
Posted: Thu Jun 24, 2010 7:49 pm
If you want this carb to work:
1st. Remove the gas filter from the carb's bowl cup. That alone increases the flow to the float bowl by 20%
2nd Replace the carb bowl cap cover and needle for the cosa 200 model. The cosa 200 needle is wider and has a better gas flow
3.On the cosa bowl cap drill this hole: http://picasaweb.google.com/Vespisti1/V ... 8492565714
to 2.3mms (use imperial -inches- size equivalent). Drill it from top to bottom so you don't damage the needle's seat
4.pass a dril bit of 1.9mm (use the imperial equivalent) to this hole
http://picasaweb.google.com/Vespisti1/V ... 5842472546
The problem of the SI is gas flow. This mods take care of it.
If you need a main jet over 128 -130 you have insuficient gas flow due to the design limitations of the carb body. For instance: The hole shown in the second picture is the one that takes the fuel from the carburator bowl to BOTH jets. It's width size is 1.6mms or "160" in tems of the SI jet sizes. Besides, it is like 15mm long. That is the reason why it restricts the fuel supply to the jets.
Note1 : Don't do mod number 4 if you dont do numbers 2 & 3 first or your gas bowl can dry out at speed.
Note2 : Once you do number 4 you will need to down jet 5 to 10 sizes dependig on were you started. Y went from 135 to 125 after I made this last mod.
Use the P/PX 200 air filter. This filter chokes the carb a little at high speed and creates the needed fuel progression that this carb would not have otherwise. remember this carb do not have a needle and progression over half-throttle would not work well without the PX filter.
The T5 SI 24/24G carb and filter has the bigger T5 filter wich does not create this condition and is VERY VERY VERY hard to set up for this reason.
Avoid the use of SI carbs without its filter You need it for prigression. You also need it becaise it catches the gas that the engine splits up out of the carb under sudden acceleration, and then enriches the mixture for a more powerful pick up.
Look at the COSA. They have a much better foam air filter inside the frame but they still use the PX filter. Now you know why.
taken from http://www.sip-scootershop.com/communit ... 09810.aspx
