dim lights
Posted: Thu Jun 24, 2010 12:01 pm
by mods64
hi all have very dim lights its 12vol all the bulbs are proper ,
Re: dim lights
Posted: Thu Jun 24, 2010 10:06 pm
by rog60
Dopes brightness of lights increase when the engine is revved. if not is probably faulty regulator??
Re: dim lights
Posted: Thu Jun 24, 2010 10:54 pm
by mods64
hi yes the lights brighten up when reved , have changed regulator, still the same when reved up. the back lights are dimer than the front .
Re: dim lights
Posted: Fri Jun 25, 2010 8:33 pm
by J1MS
Multi meter on yellow wire to check impedence back to earth, if it's too high then most likely an earth wire loose on the stator, but could still be somthing else causing the fault.
Re: dim lights
Posted: Fri Jun 25, 2010 9:22 pm
by mods64
Re: dim lights
Posted: Fri Jun 25, 2010 9:48 pm
by Daggs
Hate to shatter your illusions, but if you took the headset off and found no fault, then replaced the headset and it worked. There is clearly a fault with the connections in there.
It will come back to haunt you!
Re: dim lights
Posted: Fri Jun 25, 2010 10:00 pm
by mods64
