Scoot rs outboard disc
Posted: Tue Jun 22, 2010 2:41 pm
by bryansmudge
I have had this in the garage for a good while now, with all intentions of fitting. It is one of the early ones and have changed the caliper to the newer version (ss piston). I intend to change the master cylinder to one of the MB ones, are there any other things that require changing before fitting? And is it a good idea to fit in the first place or am I asking for trouble?
Re: Scoot rs outboard disc
Posted: Tue Jun 22, 2010 3:48 pm
by cezeta
if its got a nissin slave cylinder and it centres up in the forks ok then all i would do (and have done) is lock tite and lube every thing up.
they are well proven bits of kit but like anthing scooter related, just go through it with a fine tooth comb to make sure all is as it should be.
sometimes the disc feels warped. 500 miles clears this....usualy a high spot that wears in.
Posted: Tue Jun 22, 2010 5:45 pm
by GP Kevo
Yes, make sure it the wheel centers in the forks. Mine doesn't, I'm not sure the machining of these hubs is of consistent quality.
Posted: Tue Jun 22, 2010 9:23 pm
by byron
fit some decent braided hose, if you've still got the rubber stuff originally supplied.
Posted: Wed Jun 23, 2010 12:29 am
by shocky
dont space it away from the offside fork link as the peg thats cast into the link needs as much meat from the hub on it as poss
Posted: Wed Jun 23, 2010 12:47 am
by paulmgreen
stainless hose.... EBC HH pads..... sorted!
Posted: Wed Jun 23, 2010 10:05 am
by bryansmudge
Many thanks :bouncing:
