Indian Gear Selector..
Posted: Sun Jun 20, 2010 7:05 pm
by Supereibar
Hello peeps,
Rebuilding a 125 S1 engine for a mate. Decided to replace the gear slector and a question arises..
After putting together the gearbox, I test all the gears, the float of the shim, etc. test the spider, place the rear hub, everything seems perfect. I test the hub on neutral and I hear this scratching sound. The hub turns free but it is like the scates on the wishbone are constantly scratching/scuffing the channel on the new gear slector. Should I worry about this issue?
Regards,
J.
Re: Indian Gear Selector..
Posted: Sun Jun 20, 2010 7:32 pm
by bristolmod
I assume there is no oil in the crankcase Jaime?
If so I would expect there to be some noise- with the crankcase cover on, and filled with the correct amount of oil, then it should be OK................IMO!
Posted: Sun Jun 20, 2010 8:32 pm
by Supereibar
Hmmmm yes Chris, the crankcase is dry as a bone. No oil whatsoever. Its just weird, I have never hear this sound before. Everything looks as it should tho, no secrets inside of the gearbox I don't think, since I have not disansembled the wishbone. It is just as I left it.
I will wait until it has oil running inside then... Regards!
J.
Posted: Sun Jun 20, 2010 9:11 pm
by bristolmod
a little bit of, um, "lubrication" can work wonders Jaime.......................
Posted: Sun Jun 20, 2010 11:37 pm
by Supereibar
bristolmod wrote:a little bit of, um, "lubrication" can work wonders Jaime.......................
Heeeeeeeeeeeeeeeeeeeeeeeeeeeee
Posted: Sun Jun 20, 2010 11:48 pm
by coaster
You could always squirt some oil in there, anything would do, even WD40 just to see if the noise goes away.
colin
Posted: Mon Jun 21, 2010 11:24 am
by bristolmod
could be the edges of the brake shoes just catching on the hub?
Posted: Mon Jun 21, 2010 3:25 pm
by dirtyhandslopez
I have just fitted one to a S1 motor. Yes, on the one I have just fitted, one pad(upper) on the wishbone is rubbing on the selector in one spot, even with endplate fitted. I just took a little off the wishbone pad. Job done. I could see where it wasn't machined correctly. No surprises there.
Posted: Tue Jun 22, 2010 7:26 pm
by Supereibar
Its the defo the pads then... I tried without the hub and the noise prevails... No worries.
