Gear oil change
flipster
I need to change my gear oil after running in . Is this stuff any good ? Putoline heavy gear synthetic fortified 2 stroke gearbox oil.SAE EP80W/90 .Gadger in shop said should be ok but am not convinced . :? Cheers.
P.N.D.S.C.
hungdog
I would use SAE 90 as some synthetic oil will eat away at your clutch cork.
bristolmod
EP is no good for a standard clutch set up- wrecks the corks apparently
Scootering since 1968.
flipster
Cheers lads, said oils off back 2morra.
P.N.D.S.C.
