Fork spring height issue
Posted: Mon Jun 14, 2010 4:39 pm
by Bilko
Is there a height that the springs should sit at?
To me this looks too high, even though I don't have spring stops in.
By the way, don't get excited. That's not an extremely large condom in the back ground it's a rubber glove
Re: Fork spring height issue
Posted: Mon Jun 14, 2010 5:05 pm
by soulsurfer
Are you sure you haven't got anything left inside the forks?
Who's springs are they and how long are they?
Posted: Mon Jun 14, 2010 5:16 pm
by Bilko
Progressive fork springs from SR @ 215mm
99% sure there's nowt left in. :?
Posted: Mon Jun 14, 2010 5:38 pm
by soulsurfer
My MB ones measure 223mm but these have been used so may have compressed a little. Shine a small torch down to have a look. Does the rod pass through the spring and into the hole at the top okay?
Posted: Mon Jun 14, 2010 6:37 pm
by bristolmod
if it was a condom, I certainly wouldn't call it large anyway........................ :shock:
Posted: Mon Jun 14, 2010 8:16 pm
by Bilko
Now sorted. With special thanks to lammy mark for supplying the 12mm threaded bar!
Thanks for the help SS
Posted: Mon Jun 14, 2010 8:20 pm
by soulsurfer
No problem, what was up there?
Posted: Mon Jun 14, 2010 10:41 pm
by Bilko
There was old Stops inside the forks, when I originally thought there wasn't. Thanks to a previous post by yourself with the mention of a 12mm threaded bar and the help of lammy mark bringing round a 12mm bar, the problem was solved!
Posted: Tue Jun 15, 2010 6:57 am
by soulsurfer
Happy Days :-)
Can't take credit for threaded bar idea tho', that came from Sean Brady ;-)
