Green
Posted: Sun Jun 13, 2010 3:04 pm
No nothing to do with the England goalkeeper :bouncyeng: But the colour of my spark plug at the porcelain & the electrode
Been keeping an eye on the plug colour since fitting the Breath sweet filter & JL3 just to be on the safe side & not running too lean but I am miffed at the greenish colour of the plug.
Have done choke tests at 1/4, 1/2, 3/4 & full throttle & nowhere does it indicate that I am lean. However after doing plug chops & checking the plug after a good run out I am a bit baffled at the Green colour of the plug porcelain & the electrode In fact one side of the plug is a dark grey & the other side is a greenish colour
Hope you can make it out from the pic
The plug is an NGK B8ES with a bit of town & fast 'A' road riding.
Using same crappy unleaded fuel from Morrisons & no change to my Rock oil two stroke mixed at 4%
Is it a case of green oxide indicates overheating the plug
Rapido 225, JL3, 28phbh on Breath sweet filter, AV264 x13 @p2, 50 pilot, 120 main, 40 slide, 60 choke.
Don't want to cause damage to my engine so any advice much appreciated
