CamLam Rear Exit Fast Fuel
Posted: Fri Jun 11, 2010 10:07 pm
by paulmgreen
Just fitted one... and .... erm...... either I'm being dumb or theres something amiss!
Tap is fitted- but its like the mechanism is out by 90 degrees!
Looking at the tap its like it's turned anti clockwise - Off is at 9 o'clock with teh tap facing inwards, On is straight up, Reserve is the normal on position... and thats it!
Has anyone else fitted one?
Re: CamLam Rear Exit Fast Fuel
Posted: Fri Jun 11, 2010 10:10 pm
by Dazza
Yes and it's fine, you been on the vino?
Posted: Fri Jun 11, 2010 10:12 pm
by Dazza
Don't you just need to undo the two screws and rotate the mechanism 180 degrees clockwise?
Posted: Fri Jun 11, 2010 11:18 pm
by paulmgreen
hhhmmm don't think so dazza.... the fuel lever is 90 degrees out?
maybe if I drank some vino it would be ok lol
Posted: Sat Jun 12, 2010 5:45 am
by soulsurfer
Are you using a brass joint between the tap and lever?
http://lambrettaspares.com/spareparts/f ... l0311.html
Posted: Sat Jun 12, 2010 6:44 am
by Andy Pickering
paulmgreen wrote:Has anyone else fitted one?
Yes I have fitted one Paul and believe Eden also..mines TBH is as it should be and cant remember doing anything different from the norm..
Posted: Sat Jun 12, 2010 8:09 am
by paulmgreen
Yep! of course..
Weird ain't it!
Posted: Sat Jun 12, 2010 8:41 am
by soulsurfer
Sure is. Mine fitted okay too. I guess yours has been assembled wrong ;-? Maybe you can remove the joint or add another, or send the bloody thing back, at their cost of course
