Early series 3 headset. Ignition block?
Posted: Sat Feb 14, 2009 6:20 pm
by J1MS
Has anyone fitted an Ignition block to an early series 3 replacing the cut-out switch, I think Its possible but will I have to file the sides of the block to fit it in? any one done this lately? any advice would be much appreciated ( I know how to wire it up I just want to know if it fits in there)........... THANX
Re: Early series 3 headset. Ignition block?
Posted: Sat Feb 14, 2009 6:31 pm
by Bilko
I've had to file two LI series 3 headsets to fit ignition switches.
Posted: Sat Feb 14, 2009 6:34 pm
by J1MS
Bilko wrote:I've had to file two LI series 3 headsets to fit ignition switches.
But they will fit in ?? as I have commited to helping a mate and its one of the things that needs doing....
Posted: Sat Feb 14, 2009 7:16 pm
by lammydave
they will definatly fit .. after a bit of filing, doesn't take much...
Posted: Sat Feb 14, 2009 7:18 pm
by Bilko
All I can say is both mine fitted nicely after I ground down the bits inside the LI headsets. Maybe one of the more experienced here can confirm for definite that it's ok on all LI headsets.
by Bilko
There you go.
