help
Posted: Tue May 25, 2010 8:24 pm
by oggy
my handle bar hyd brake is leaking past the piston seals,had it chromed and fitted a new seal an piston kit,im using synthetic fluid but as its a gremica type of a moto morini and is old would it attack the seals or wot type would you reccomend. ta
Re: help
Posted: Wed May 26, 2010 7:43 am
by coaster
oggy wrote:my handle bar hyd brake is leaking past the piston seals,had it chromed and fitted a new seal an piston kit,im using synthetic fluid but as its a gremica type of a moto morini and is old would it attack the seals or wot type would you reccomend. ta
Did you check to see if there was any scoring or corrosion inside the bore? If the seals have reacted to the silcon fluid it wouldn't happed straight away, it would take weeks or months
Re: help
Posted: Wed May 26, 2010 3:35 pm
by oggy
Thanks,the bore looked good,is it best not to use sthyn fluid as its very thin type.
Re: help
Posted: Wed May 26, 2010 7:14 pm
by coaster
oggy wrote:Thanks,the bore looked good,is it best not to use sthyn fluid as its very thin type.
I have no experience of scooter hydaulics but I've found synthetic fluid to be fine in my classic Marcos, I have replaced seals form time to time over a period of years but due to it no absorbing water like normal fluid I havn't had any corrosion problems. Plus it won't hurt your paint if it leaks.
Hopefully someone will be along soon who knows about scooter hydraulics
Re: help
Posted: Sat May 29, 2010 4:45 pm
by sideout
coaster wrote:..... my classic Marcos
mmmm....... Marcos...........
Sorry Oggy, couldn't resist
