bgm/varitronic
Posted: Mon May 24, 2010 7:04 pm
by doggbhoy
i currently have varitronic fitted but i dont feel it retards enough when at mid range /cruising, coming off the throttle, stator fully retarded.... sometimes hear pinking,re jetted many many times and feel it is ignition related and i'm getting fed up and thinking will a bgm stator work with varitronic flywheel then fit an augusto advance/retard type thingy?
i run a tuned mugello 225
any help appreciated thanks
Re: bgm/varitronic
Posted: Mon May 24, 2010 7:44 pm
by firekdp
The two systems are incompatible, so unfortunately, you can't use a varitronic flywheel with a BGM stator.
Re: bgm/varitronic
Posted: Tue May 25, 2010 10:13 am
by paul213
you could just retard the timing on the varitronic just rotate the stator clockwise a little at a time until the pinking stops . this will retard the timing throughout the rev range .
have you checked your compression ratio this could be too high
Re: bgm/varitronic
Posted: Wed May 26, 2010 6:07 pm
by doggbhoy
ok guys thanks for the replies,
unfortunately stator is fully retarded
Re: bgm/varitronic
Posted: Thu May 27, 2010 10:17 am
by paul213
if you file the slots you can retard it further
