sealant
Posted: Mon May 24, 2010 6:26 pm
by oggy
Just got it started,and got a oily leak from the down pipe joint even with scoot loopy clamp,does everybody use silicone sealent or different type,cheers
Re: sealant
Posted: Mon May 24, 2010 8:30 pm
by J1MS
RTV silicon. High heat silicone and high temperature sealant.
Use google to find it.
The RTV sealan. I am using now was bought by a mate, it's meant for sealing oven door glass and seems to cope with the heat of the expansion chamber well.
Cost about £6.00 for a tube that fits in a mastic gun.
Re: sealant
Posted: Mon May 24, 2010 10:39 pm
by oldbiker
J1MS, Is this the stuff that you are on about?
Re: sealant
Posted: Tue May 25, 2010 11:24 am
by J1MS
tzr.steve wrote:J1MS, Is this the stuff that you are on about?
Similar stuff, the one I'm using is supposed to resist temperatures upto 300c I think.
Will find out what the make is and let you know!!!
Re: sealant
Posted: Tue May 25, 2010 7:55 pm
by goldeneye
use cheapo bathroom silicon from B+Q (no, i dont live there!) the one that smells of vinegar. smear loads round joint, clamp up, leave overnight, scalpel off excess. no leaks. about 3.50 a (massive) tube. ive used it for years, and it works, and easy to get, and cheap.
Re: sealant
Posted: Tue May 25, 2010 8:12 pm
by mark
B&Q sealant for me as well :P
Re: sealant
Posted: Tue May 25, 2010 8:20 pm
by oggy
Thanks all :)
Re: sealant
Posted: Wed May 26, 2010 1:00 pm
by dapper
RS Components 283-426 Silcoset 158 up to 300 C
