wiring: front light now - aaaaagggggh
druist
I fixed my rear brake light and now i seem to have a problem with my front light and parking light - they dont light up and did before i moved bits to get the rear brake light working- which it is now. Anyway it is wired up the front ok. I noticed a spark from the common when it touched the headset as though it was shorting, but when in situ it and the side light just dont light up.
The only thing i can put the problems down to is the junction box. There is a yellow which comes from the regulator and it isnt with anything else - should it be? There are 3 greens which i have put in the one with green blob, one mauve or nearly grey which is on its own and a red in the middle with nothing in the other connetor. The purple/brown not sure what it is is at the bottom where its marked brown. Except the yellow which doesnt have a mark all the others are colour coordinated.
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 1 guest
