Page 1 of 2
175 kit
Posted: Sun May 23, 2010 6:32 pm
by LI150
Im going to upgrade my series 2 engine firstly I cant afford a muggelo,rt, imola etc so Im going to put on a 175 kit. I have a jetex and a AF clubman so will be run with these. What I dont no is what is best.
Should I
1. Buy an of the shelve kit?
2. Take a 150 barrel out to 175, If so what piston should I use and what is the best barrel to use as in a gp150 or li etc.
Re: 175 kit
Posted: Sun May 23, 2010 6:35 pm
by Andy Pickering
Get a good quality piston..maybe asso or the like and get some decent porting work on it..you know the man. ;) my stage 4 has exceded all my expectations..
Re: 175 kit
Posted: Sun May 23, 2010 7:19 pm
by CPH Lambretta
Which of the many men would that be?
Re: 175 kit
Posted: Sun May 23, 2010 7:46 pm
by sideout
It has been noted that some 175 kits have small piston - bore clearance. This could lead to seizing, however carefully they are run in. If you go this route it's worth checking before you fit. :| I know, I've been there :roll:
Re: 175 kit
Posted: Sun May 23, 2010 8:05 pm
by Andy Pickering
CPH Lambretta wrote:Which of the many men would that be?
The man we have both used to great effect..!!!
Re: 175 kit
Posted: Sun May 23, 2010 9:08 pm
by LI150
Lam46 wrote:Get a good quality piston..maybe asso or the like and get some decent porting work on it..you know the man. ;) my stage 4 has exceded all my expectations..
So its prob best to get a 150 barrel bored out and a decent piston as appose to a of the shelf kit :?
Re: 175 kit
Posted: Sun May 23, 2010 9:15 pm
by Andy Pickering
Prob cheaper as you might not get a decent quality piston..
Re: 175 kit
Posted: Sun May 23, 2010 9:19 pm
by LI150
Any idea mate what would be the best 150 barrel to use or would it not make much difference seeing as I will get some porting work done on it
Re: 175 kit
by sean brady scooters
actually ...i would go for and recomend the AF 175 kit...and then get that sorted and ported...as opposed to any bored out 150 /or 175 cc cast cyl... :D
Re: 175 kit
Posted: Sun May 23, 2010 9:26 pm
by LI150
Is the piston up to the job with the AF kit Sean
