Drum Brake Spindle
Posted: Thu May 20, 2010 5:05 pm
by soulsurfer
Is there any way a large bolt could be used as a spindle in a Lambretta drum hub instead of the usual affair with nuts either side?
Re: Drum Brake Spindle
Posted: Fri May 21, 2010 11:09 pm
by wack 63
I wouldn't have thought so as the backplate will knock back and forth on the link peg possibly breaking the boss off.I have the PM tuning twin disc that has a bolt for the axle and quite honestly it is a pain in the arse to get everything back in the links and then tighten up.When I have time I'll try and find a longer axle and go back to the standard arrangement.
Posted: Sat May 22, 2010 8:12 am
by soulsurfer
I'm not using the link peg, using antidive but you just reminded me, I used to have the PM single disc antidive :roll:
