Page 1 of 2
Hydrolic clutch
Posted: Thu May 20, 2010 8:16 am
by Fux
what are the options available for a hydrolic clutch?
Re: Hydrolic clutch
Posted: Thu May 20, 2010 8:32 am
by mark
Cs engineering does the best fully hydaulic one in my opinion or you can drill and tap a Kawasaki one onto the side casing , someone was doing a bebo mini bike stye conversion i think.
Re: Hydrolic clutch
Posted: Thu May 20, 2010 8:42 am
by Fux
mark wrote:Cs engineering does the best fully hydaulic one in my opinion or you can drill and tap a Kawasaki one onto the side casing , someone was doing a bebo mini bike stye conversion i think.
I know CS do some sweet ones, but I was hoping to find something a little cheeper. I can`t remember the exact price but they are $$$$$$ .
Re: Hydrolic clutch
Posted: Thu May 20, 2010 9:24 am
by shocky
there was one on ebay a few weeks ago that used a minimoto /auto parts need some welding on the handle bar mount to accept the speed flight master cylinder bottom looked like this one that i used
Re: Hydrolic clutch
Posted: Thu May 20, 2010 11:05 am
by coaster
shocky wrote:there was one on ebay a few weeks ago that used a minimoto /auto parts need some welding on the handle bar mount to accept the speed flight master cylinder bottom looked like this one that i used
Steve, what would thre resultant clutch action be like with say a 5 plate clutch with competion spings in?
Re: Hydrolic clutch
Posted: Thu May 20, 2010 1:12 pm
by shocky
i dont know col mine was light enough though took a bit of fiddling to get it right the main prob was locating the bit in the pic as it couldnt be muonted straight couse the cable adjuster bracket was in the way i ended up makeing a new adjuster bracket with a longer tab on to take this i got a pic some were
Re: Hydrolic clutch
Posted: Thu May 20, 2010 1:31 pm
by coaster
shocky wrote:i dont know col mine was light enough though took a bit of fiddling to get it right the main prob was locating the bit in the pic as it couldnt be muonted straight couse the cable adjuster bracket was in the way i ended up makeing a new adjuster bracket with a longer tab on to take this i got a pic some were
I'd be interested to see it if you come across it
cheers
colin
Re: Hydrolic clutch
Posted: Thu May 20, 2010 2:58 pm
by Fux
Hmm. The fact that I have a standard 1 inch bar make fitting hydrolic sylinders a piece of cake.
Looks like a neat gadget, worth a try I guess.
Re: Hydrolic clutch
Posted: Thu May 20, 2010 4:10 pm
by martinr
i use one of those on my cutdown works fine
Re: Hydrolic clutch
Posted: Thu May 20, 2010 6:10 pm
by shocky
i have 2 of them left
