Auxilary Fuel Tank for long distance
Posted: Wed May 19, 2010 9:43 pm
Here's my bright idea:
-Fit a 3 gal fuel cell, with approximately the same depth dimension as a stock tank, inside the leg shield.
-mount the fuel cell with its top at the same elevation as the top of the stock tank
-Run a 1/2" fuel line hose between the bottom of each fuel tank.
-fit two shut off valves as close to each tank as possible.
-let gravity do its magic.
Since liquid will always seek its own level, and the top of the two tanks is the same, I'm thinking the larger fuel cell will keep flowing into the stock tank, but not overfill it. The 1/2" fuel line will allow the pressure from gravity to always be greater than the pressure needed to keep fuel flowing though the 5/16 line from the stock tank into the carb. Both tanks vent at the top to equalize outside air pressure. Each shut off valve is used when re-fueling to keep the fuel line between the tanks from filling up with oil. The tank itself, being inside the leg shield will keep the center of gravity lower than if I tried to fit some gravity fed tank system on a rear rack. If the added fuel cell is deeper than the stock tank, I believe any fuel in the cell, below the level of the bottom of the stock tank, will never transfer.
I keep my stock looking scooter with tool and airbox intact. The entire rig is reversible, sans capping the 1/2" fitting in the bottom of the stock tank, and avoids messing with the existing fuel delivery system to the carb.
Is this totally stupid?
