Mallossi 172 Jetting
Posted: Wed May 19, 2010 6:33 pm
by steeleyscoot
Help please...
My mate has got a T5 Classic. Can someone recommend 'ballpark' jetting/slide/airscrew setting for a standard Dellorto 24/24 carb running a Mallossi 172 kit with a Simonini exhaust.
Everything else is standard, no porting/fettling to the cylinder or casing's and standard T5 gearing.
Cheers.
Re: Mallossi 172 Jetting
Posted: Wed May 19, 2010 6:50 pm
by skidmark
My Mrs runs a T5 Malossi 172, Sip head, standard 24mm carb set up, standard Exhaust, on a 122 main jet and it has run sweet for a few years now. ;)
Posted: Wed May 19, 2010 7:05 pm
by gaz_powell
mate of mine has one very similar which i built
casings matched to kit and correct head, SIP Performer exhaust everything else standard
carb just upjetted on the main to 125
bulletproof
would start at 125 main and you can come down if necessary
he doesn`t run the autolube and use 3% Putoline tt sport
Posted: Thu May 20, 2010 8:27 am
by fatherjackhacket
I agree with above...my 172 running a sito plus runs a 125 main..good plug colour so far so good :bald:
Now with sterling pipe and still running 125 main...still so far so good :geek: :geek:
