BGM stator plate and battery.
Posted: Tue May 18, 2010 1:19 pm
Is it possible to add a battery when using a BGM stator?
The scooter previously ran with a battery, the battery loom is still in the frame. I do recall that it had a zener diode fitted and was on points but I ditched the original flywheel and zener as I was just going to stick a new electronic loom and 12 volt kit on it. original stator has gone into hiding too. For improved lighting (thinking of fitting some S type spot lights) I'd like to retain the battery.
