Carb to inlet manifold
Posted: Mon May 17, 2010 2:46 pm
Help please,
When attaching my carb (sh1/18 dellorto) I cant get to sit tight on the manifold, no matter how tight the clamp is I still get some side to side movement, enought for it to slip off.
Is this normal? its a new manifold so that should be OK, and I replaced the clamp (which is the correct size (18m), and still no joy (i cant remember of it was tight when taking off
is there some sort of sealant I can use so it sits tightly ? I replaced the plastic sleeve as well in the carb.
Any ideas would be appreciated ......
