durafix easyweld
Posted: Mon May 17, 2010 10:09 am
by weller51
hi,has anyone used easyweld ? can you tell me if it would repair a small hole in my leggies ??? any answers would be great
Re: durafix easyweld
Posted: Mon May 17, 2010 10:16 am
by dapper
Never used it meself, but some mates who have tried it say you have to get the ally very hot indeed and you must use a stainless steel wire brush to clean the ally first. BUT you say mend a hole in your leggies which are steel and should be MIG welded.
Posted: Mon May 17, 2010 11:40 am
by shocky
its not a weld but a surface bond a bit like braze there will over time be some reaction between the alloy and the steel causing it to bubble or
oxidize and basically feck ur paint
Posted: Mon May 17, 2010 12:26 pm
by minotaur
no good for leggies, used it to good effect on engine cases, need to heat to 350° first need a good blowtorch, tough stuff when used correctly,
