Mikuni+ Taffspeed TS1 225
Posted: Sun May 16, 2010 10:35 pm
by bendikb
Hi
I could not find this combo in any other post. Please feel free to point me in the correct direction If I missed a post.
Set up;
Mikuni carb
Tasserini reed
TS1 225 w/ Taffspeed road tune
MBD piston
Taffspeed road exhaust
HPC crank w jap rod conversion
Af flywheel with Indian stator so no variable ignition as for now..
Any ideas on where to start?
Re: Mikuni+ Taffspeed TS1 225
Posted: Wed May 19, 2010 5:13 pm
by bendikb
Nobody? There ought to be somebody out there with a similar TS1 and TMX 35?
Posted: Wed May 19, 2010 7:58 pm
by drunkmunkey6969
Try searching here first, there are a few setups you can compare: http://scooterotica.org/forum/viewtopic ... 14&start=0
Also, your second post now states it is a 35mm so people can at least make some suggestions, you'll probably find that a good starting point is something like this:
Standard slide, 56 needle, 2nd clip, 320 main, 20 pilot.....start there and lean/richen up as your setup requires according to plug chops. If happy then crack on, if you want a more precise setting and/or peace of mind, then get it booked in at your local scooter dyno specialist.
Posted: Thu May 20, 2010 9:44 pm
by bendikb
Thanks! I'll use that as a starting point. I can assure that my local sooter shop does not have a dyno :lol:
