Yamaha R1 Shock Question?
Posted: Thu May 13, 2010 6:14 pm
by Gsvespa
has anyone heard of the r1 shocks snapping or breaking when fitted to a lambretta? I recall reading about them being a problem, but can't find that info now?
I am a pretty Fat b@5t@rd & don't want to take any chances.
Thanks,
Bill
Re: Yamaha R1 Shock Question?
Posted: Thu May 13, 2010 6:18 pm
by sean brady scooters
we have covered this topic/issue before on here...have you tried a "search"..?
heres one
http://scooterotica.org/forum/viewtopic ... er&start=0
Posted: Thu May 13, 2010 10:36 pm
by shocky
only if you use metal bushes and do the shock up with out half nylocks the same as the taffspeed.bgm,readspeed or GAZ ones if there fitted incorrectly
Posted: Fri May 14, 2010 12:25 am
by Gsvespa
Thanks for the help!
I've got the Clauss studio nylon bushings...not metal....
Is there a rule of thumb for the amount of play you want between the nut & shock top?
Posted: Fri May 14, 2010 9:55 am
by shocky
none just tighten the nut till it bites when u push down on the scoot you should see the shock eye rotate slightly i found(having imported 100 sets) that the clauss bushes are very soft and have a tendency to crumble if you have any probs with stripping the shock or fitting a new spring call me on 07756974741 as ive dona few ............hundred of these in the last 5 or so years :D
