Varitronic, headlight works, horn & rear lights don't
Posted: Tue May 11, 2010 7:11 am
by lakelambrettas
I've fitted a Varitronic to an Li175 with electronic loom. The problem I have is that the headlight works but the horn and rear lights don't. This to me signifies that the problem must lie within the headset as power is getting to it. However the person who I've done the job for tells me that they were working before he gave it to me, suggesting that it must be something I've done.
I'd take the headset off and have a look but he's got a flyscreen fitted so before I take the plunge has anyone got any suggestions other than headset?
Cheers.
Denis
Re: Varitronic, headlight works, horn & rear lights don't
Posted: Tue May 11, 2010 9:14 am
by boxofbits
see if horn wires are pluged into the horns back light is usally the earth at the rear -- i quick test is to get a bit of wire and stick it on the screw of the back light then earth it --
Posted: Tue May 11, 2010 1:38 pm
by lakelambrettas
I'll check the earths at the back, thanks.
Denis
Posted: Tue May 11, 2010 1:50 pm
by firekdp
If it's got an electronic loom and the horn and rear light are affected, then it's got 2 separate problems and I can't see how it's anything to do with the work you've done.
Posted: Tue May 11, 2010 3:35 pm
by lakelambrettas
firekdp wrote:If it's got an electronic loom and the horn and rear light are affected, then it's got 2 separate problems and I can't see how it's anything to do with the work you've done.
I agree, but the chap tells me they did work, I can't prove otherwise as it was a non-runner when he brought it to me.
Denis
Posted: Tue May 11, 2010 7:18 pm
by JOHNNY
If it was a non runner how did he know they worked ?
Posted: Wed May 12, 2010 8:09 am
by lakelambrettas
JOHNNY wrote:If it was a non runner how did he know they worked ?
It became a non-runner when the flywheel came apart when he was riding it over to me.
I took the screws out of the light switch yesterday and it fell apart! I hope that is the is the problem solved.
Denis
PS It was the cause, problem solved.
