Jetex Choke Jet
LI150
Main scooter: Series 2 LI150
Running a 150 top end on my LI with a 42mm Clubman and a jetex through air box. When cold it takes a bit to get started Im running a 50 choke jet, whats prob best jet to try to sort this as dont no wether I need to go up jet size or down all help appreciated. :bouncing:
J1MS
The 50 choke jet that's in there should be good, check its not blocked and make sure the choke cable is adjusted correctly so that the choke plunger can be seen to lift at least halfway clear, this is visible through the air intake at the front side of the carb directly below the choke assembly...
LI150
Plunger lifts good and not blocked so Im now quessing that if I change to a dellorto choke jet all should be good cheers for advice.... :lol:
    Users browsing this forum: Google [Bot] and 25 guests
