Page 10 of 10
Re: Shed Find (My Shed)
Posted: Sat Jun 18, 2016 10:20 pm
by rosscla
After last nights debacle, this evening I decided to tackle the rear hub. That should be a nice easy job. The hub that was on was relatively new so it was easy enough to get the studs out of. I stripped it all out and removed the SIP studs from the other newer rear hub and fitted them to the one that had been on it.
I fit the hub back on and torque it up. This is going quite well.
I offer up the wheel and find that one of the studs is ever so slightly on the p!ss. The tighter tolerance on the SIP wheel and the longer stud means that it won't go on. Obviously with the shorter stud and the normal type wheel this wasn't really an evident problem. More cursing and swearing ...
So I strip the hub down again, put the studs back in the newer hub, check that the wheel actually fits on the hub before I fit it and torque it up and fit the wheel. Four hours of spannering and one wheel fitted. No wonder I don't play the lottery anymore.
Still at least the 'not tight' sticker is gone from the hub at last.
Now just the front end to sort out, but moves are afoot on that front.
Posted: Fri Jun 24, 2016 12:44 am
by rosscla
Given the issues I've had, I bit the bullet and decided to get a more modern disk brake for the front end, the SIP studs fit, the wheel fits, everything lines up nicely. There is no more catching or rubbing.
Got eaten by midges while fitting this tonight so match was abandoned before I got round to bleeding it, but it looks the good from the pavement side.
I need to sort out the speedo sensor or go back to a cable but that's not a showstopper.
Get it bled and the timing sorted and I might be ready for an MOT. Getting exciting.
Posted: Fri Jun 24, 2016 9:27 pm
by Rs fruitbat
Good luck with the mot :mrgreen:
Posted: Mon Jul 18, 2016 12:04 am
by rosscla
I'd set myself a target to have this ready for Mull but weather, holidays and work conspire against me at every turn.
Last two days I've gone at it hell for leather, got the timing set and strobed. Had a bit of bother with the holding tool which slipped as I was removing the flywheel to move the stator and I chipped a fin. I was a bit annoyed by that as its an original AF one.
Anyway got that done, dust cover on and the cowling on. Also gave the carb a last check.
Also fitted the rear mudflap and the spare where carrier / rack. Can't get a wheel on with the electronic seat but may swap it out later anyway as I originally wanted to have a square back but the one I have has a rusted hinge.
Fitted the footboard and bridge piece which was a total faff as the temporary crappy far eastern foot boards are a shocking fit, quite a bit of drilling and filing gets them on, sooner I get the originals painted and swapped out the better, these'll have to do for now.
Adjusted the rear brake and I think I'm done.
Working away Monday / Tuesday so going to try set up the MOT for Wednesday. it may make Mull yet!
Posted: Mon Jul 18, 2016 12:29 pm
by Toddy
Look forward to seeing it there good luck and well done great thread :D
Posted: Tue Jul 19, 2016 12:36 am
by paul d
Great thread! I think I'll celebrate myself when you get that MOT!
Posted: Tue Jul 19, 2016 6:57 am
by warts
That is looking nice!
What doesn't kill you, makes you strong.
Posted: Tue Jul 19, 2016 6:49 pm
by T5-190
Agreed, good strong thread. Very good work.
Posted: Tue Aug 30, 2016 9:20 pm
by ridden not hidden
great thread that reminded me of the scooters I used to build, with spraycan paintjobs and having to use and refurbish what you had. They may not have been perfect (in my case) but they didn't need to be and put as big a smile on my face as any custom I have built! :-)
